lost
Old Apr 8, 2006 | 08:03 PM
gasman305h.o.'s Avatar
Car: 1984 Pontiac Trans Am
Axle/Gears: 9 bolt posi 3.27
lost
what would cause a brand new engine to have 0 compression?
Old Apr 8, 2006 | 08:06 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
haha, ouch! does it run?
across the board, or only on certain cylinders?
-loose fitting on your test
-forgot some rings
-forgot some pistons
-forgot some valves
-gigantic crack in block or heads
Old Apr 8, 2006 | 08:08 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
incorrect valve adjustment
Old Apr 8, 2006 | 08:52 PM
the starter turns it, and i've only checked the #1 cylinder for compression and it didnt even move the needle. but i did put a higher lift cam in it so i hope its just needs a valve adjustment.
Old Apr 8, 2006 | 09:30 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
How did you tighten the rockers?
If their cranked down too much the valve can stay open and "leak"
Old Apr 8, 2006 | 10:08 PM
yeah thats what it was, i backed the rockers off a 1/4 turn and i get awsome compression now, thanks for the help
ZZ3Astro
Aug 13, 2019 12:57 AM
djmarch
May 8, 2016 11:32 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Jynx88
Oct 4, 2015 08:19 PM
3.8TransAM
Sep 27, 2015 08:37 PM
