Faulty TPS Sensor?
Old Apr 8, 2006 | 11:30 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Faulty TPS Sensor?
Ok, isnt the car supposed to idle real high when the TPS is unplugged?
Because, I currently have an electrical problem with my car, dont know whats causing it, but I unplugged the sensor while the car was running, and the idle didnt change one bit, yeah the SES light came on, but no idle change.
Isnt the car supposed to idle fast with the sensor unplugged?
Is my sensor bad?
Old Apr 8, 2006 | 11:37 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Try measuring the voltage output of the sensor in the idle position... It should be ~0.6 volts (anywhere from 0.45 to 0.65 is considered acceptable)... As you increase the throttle position, that reading should approach 5 volts smoothly (do this with the ignition on, engine off)..
Unplugging it won't change the idle..
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
bbsr72
Apr 2, 2016 09:12 AM
BumpaD82
Feb 26, 2016 02:57 PM
BWilcox
Sep 20, 2015 12:19 PM
