What is this? Where does it go?
Old Apr 9, 2006 | 09:10 PM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
I bought a TPI setup and this was enclosed in the box. Not real sure what it is. So..........any thoughts?
Old Apr 9, 2006 | 09:50 PM
camarodarrell's Avatar
The bottom is an EGR solenoid. It is located in between the lower intake and the plenum at the rear and is bolted on with the same bolt as the remote coil. A connector plugs into the back and the vacuum lines go to the egr valve and to the throttle body.
Old Apr 10, 2006 | 05:04 AM
techno101's Avatar
Car: 1989 Camaro RS
It was origianlly off of a 305, will it work on a 350?
Old Apr 10, 2006 | 05:35 AM
joe350's Avatar
Car: 91 Z28
Engine: 350 TPI (L98)
Everything is the same on a 305 as a 350 except the injectors.
Old Apr 10, 2006 | 05:48 AM
Vader's Avatar
...and the knock sensor / ESC.
Old Apr 10, 2006 | 05:45 PM
techno101's Avatar
Car: 1989 Camaro RS
ESC.......electronic spark control? This is located where?? Does anyone have picture of their firewall or egr routing? I swapping from tbi to tpi and I don't have a Helms manual.
