oil weight based on tolerances right?
Old Apr 11, 2006 | 07:00 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
Im about to change the oil in my new 383 for the 2nd time (1st was after cam break in), and I was wondering about a couple of things. Ive heard numerous times that you shouldnt run synthetic until after the first 500 miles. is this true for all motors or what? Mine is not a daily driver, so it will be a while before it ever has 500 miles on it. I was just wondering if I can go ahead and switch to Mobil1 or if I need to wait (motor has maybe 80 miles on it, I wanna change it because its lookin kina dark).
2nd, what is oil weight based on for each motor? I mean if you have stock tolerances with a hi-volume oil pump can you still use 10w-30? Im already regretting putting the hi-flow in since I still have the stock pan, so for now Ill have to deal with it. Anyone have any problems with using a hi-volume pump with stock tolerances? But either way I was just curious as to what its all based on.
Old Apr 11, 2006 | 07:25 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
1) It is said not to use synthetic during breaking due to parts not actually being able to break in (less initial wear) If the motor has had a few hours run time (being the 3rd change i would assume so) Their should be no problem going synthetic now.
2) Yes oil weight selection depends on what size bearing clearances it has to 'fill', i would say stick with 10w30.
Old Apr 11, 2006 | 07:26 PM
Scmx8's Avatar
Car: 1991 camaro rs
Engine: v6
Transmission: auto
i know that synthetic oil will not let the rings seat properly to the cylinder walls. as far as the tolerances that's a little out of my league
Old Apr 11, 2006 | 07:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you want to know whether the rings are ready for synthetic oil, do a leak-down test.
If the shop that did the final cylinder honing had any clue about what they were doing, the rings are most likely seated by now.
Any clue what the final bearing clearances were? If they were loose, use xW-40. If tight, use xW-30.
Old Apr 11, 2006 | 07:39 PM
spills's Avatar
Car: 89 RS
I cant remember the tolerances off hand, but I know they were close to factory specs.
BTW: would a compression test show the same as a leak down test? I remember that just about every guy in my shop's got a compression tester, but they all look at me funny when I ask for a leak down tester.
Old Apr 11, 2006 | 07:44 PM
five7kid's Avatar
A compression test might help a little if you know what the compression pressures were before you fired it up.
You can get a leak-down kit from Harbor Freight.
Hotrodboba400
Dec 10, 2019 07:07 PM
carattini
Sep 10, 2015 07:46 AM
roysatikas
Sep 7, 2015 08:08 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
