Code 24 - no speedo, but car runs fine...?
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
My car just threw a code 24 today and the speedo stopped working. From what I have been able to gather, if the ecm doesn't see the vss signal, the car will run crappy. My car runs fine, so I must assume the vss is functioning. What else will cause a code 24 and disable the speedo?
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
the vss may not be sending proper pulse to the ecm but still functioning or known as a lazy sensor check your cruise control for functionality if u have that option it wont usually work if the vss is fried / dying
My car didn't come with cruise control. Any other things I can check?
beachrodder
Aug 7, 2015 04:27 PM
