ticking lifters
Old Apr 15, 2006 | 12:52 PM
slickfbody's Avatar
Car: 91 camaro z28
Engine: 350 modified
Transmission: 700R4 modified
ticking lifters
Anyone having the same problem? Can't seem to get away from it even after tightening them.
Old Apr 15, 2006 | 02:04 PM
rezinn's Avatar
You think your rocker arms are ticking? Some fuel injectors make a ticking sound, but rockers are more of a clacking loose sounding... sound. If your lifters are making noise they probable need replacement.
Old Apr 15, 2006 | 02:15 PM
slickfbody's Avatar
Car: 91 camaro z28
if it's the injector's, there pretty loud. There are one year old svo 30lbs injectors.
Old Apr 16, 2006 | 12:41 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Yuppers. Those would be injectors. My SVOs are so loud you can hear them at a stoplight. Everybody thinks its the rockers, but its the injectors.
Go back and loosen your rockers. Might as well adjust them with the car running also. Back off the nut till you HEAR the rocker. Then tighten till it stops and add a 1/4 turn.
Old Apr 16, 2006 | 03:13 PM
slickfbody's Avatar
Car: 91 camaro z28
Thanks for the info, that sucks though. Can we quiet the injectors? Clean them or something.
Old Apr 16, 2006 | 05:55 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
you think the injectors are loud....you should hear my holley blue fuel pump in the back of my car. Now that's LOUD.
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
