Cr@p or not?
Car: Silver 1980 Corvette (L82 w/TPI)
Engine: L82
Transmission: TH350
Cr@p or not?
Guys/Gals-
eBay Motors: Late Model CHEVROLET V8 HEI Distributor 3year (item 8055576039 end time Apr-17-06 18:47:34 PDT)
Is this distributor any good? It is quite cheap. I don't actually have a distributor and I was looking for one for a future TPI retro-fit project I am working on. I'd rather not roll the dice with a salvage yard piece.
Thanks!
Thanks!
Transmission: 4L80E/4L80E
Some people have done okay with off-brand distributors, others have had problems. You might ask them to post a picture with the cap removed and looking straight down at the distributor - corrosion was the previous complaint that comes to mind (no idea personally, otherwise).
(See if you can shrink that photo.)
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Heres a smaller pic so it doesnt make the board format go way out to lunch!!
Looks like that piece needs a bit of TLC, runners got a fair sized ding in it!
Engine: L82
Transmission: TH350
I guess as long as the distributor works and works well it doesn't matter who makes it. It is going into a weekend cruiser, not an 1/8 mile terror. As long as it fires the wires and doesn't eat the cam I'll be happy.
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
i have bought from that seller and was very pleased. also bought same mfg. dizzy but different model and it has worked great
