Lug nut thread size?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Most if not all third gens are 12mm x 1.5. I'm not sure the exact year GM switched to metric wheel studs. The pre metric studs will be 7/16" NF
Stephen is exactly right. I think "someone" is mistaken.
You can look them up in the lug nut section of AutoZone or some such, basically anywhere that sells wheels.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
my '82 TA uses metric lugnuts as well, I think the studs and nuts are stamped "metric".
New2Chevy
Sep 28, 2015 12:35 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
