1.6 rockers and pushrods
Old May 7, 2006 | 02:52 PM
Casey_Butt's Avatar
If I go to 1.6 rockers can I still use the stock length pushrods?
Old May 7, 2006 | 02:53 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i did, but you MUST use a pushrod length checker, its all about geometry.
P.S. - i have a comp cams adjustable 7.8 - 8.8 if you need it.
Old May 8, 2006 | 05:26 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Yes. I just fired my new L98 with trickflow heads, stock cam, stock length 7.2 hardened apr pushrods and summit (noisy ***) 1.6 roller rockers. The geometry is dead on. These heads use guide plates but you need to make sure your heads have enough clearance for the pushrods as the 1.6 rr's will alter they're location where they come through the head. You need to be sure if you need self aligning or not and you may encounter valve cover clearance issues also. If you want my recommendation DO NOT cheap out on the quality of the roller rocker you buy! The summit brand are NOISY!
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
slowsi
Oct 18, 2015 08:49 PM
Jorlain
Oct 8, 2015 01:57 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
mfp189
Sep 27, 2015 09:25 AM
