Electric or Mechanical Gauges???
Old May 9, 2006 | 05:43 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Im looking at a custon gauge setup for the maro but am at the very start...Should i go with mechanical gauges or electric gauges (mechanical being cheaper usually)
also (equally as important) can I use a mechanical speedo with my T-5? (which will be converted to probably a TKO-600 so it has to work for that too).
Im looking at the zseries gauges form autometer but they only come with a mechanical speedo...
Old May 9, 2006 | 05:48 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I like electronic but everything has its pro and cons...
Elec pros- fast readout, accurate
elec cons- expensive, just like any electronic device can go haywire on ya
Mech pros- cheap, seem to last 10x longer than the car
mech cons- slow readout
As for the speedo it all depends on the sending unit you have or can get. Shouldnt be a problem to go mechanical or electric there.
Old May 9, 2006 | 07:56 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I prefer mechanical where possible. Sorry, can't help on the speedo (don't have one).
Old May 10, 2006 | 06:05 PM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
what did you do find a custom cluster replacement or? I want one for my firebird.
that and if has fit about 12 gauges in their car how? and did it look good?
Old May 11, 2006 | 12:53 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
I basically made my own. Function over form: just a piece of sheet of metal, cut some holes in it and put it it. Nothing fancy or even that good looking. I only have 6 gauges though.
Old May 11, 2006 | 05:47 PM
Car: 91 RS
Engine: 5.0 tbi
well figure I plan on running front and rear brake presure, left and right air/fuel, fuel pressure, oil-coolant-trans temps, volt, oil pressure, fuel level, speed, rpm........and if I can find the room head and block temp
Hotrodboba400
Dec 10, 2019 07:07 PM
TrevinE
Sep 14, 2015 03:20 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
jtwoods4
Sep 3, 2015 05:39 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
