Pull through stock fuel pump?
Old May 10, 2006 | 01:08 PM
oxiderush's Avatar
Car: 90 firebird
Engine: 350 5.7L
Transmission: Th-400 w/ Manual valve body
Axle/Gears: 4.10 Richmond gears
I want to go to a manual fuel pump, for my new motor. I'm running new fuel lines and want to know if i can hook up to where the old pump came out of the tank. Thanks.
Old May 10, 2006 | 02:57 PM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
it didnt work for me, i couldnt get enough fuel to my 650 carb. i had to remove pump and attach a pickup line.
Old May 10, 2006 | 03:37 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
You will most likely not be able to pull enough fuel through the stock in tank pump.
Either keep the elec pump and use a regulator or intall a pickup in the tank.
Old May 15, 2006 | 09:07 AM
oxiderush's Avatar
Car: 90 firebird
Engine: 350 5.7L
well, just one more thing keeping me off the road. I guess it'll be fine because the sheetmetal inside the car was removed before to access the fuel tank, do i can get it open again real easy. Thanks for the replies, saved me some time.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
