Small Block Drain Plugs
Old May 16, 2006 | 07:08 PM
gcore45's Avatar
Car: '91 RS
Engine: 5.7 tbi
What are the specs for the coolant drain plugs on either side of our small blocks? These are the ones with the allen head and are only about a 1/4 inch long.
I'm missing one and need to know what I can replace it with until I can find it.
Thanks,
GC
Old May 16, 2006 | 07:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
One (driver's side) has a plug. The other (passenger side) has the knock sensor.
Old May 16, 2006 | 07:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
They're 1/4" NPT. I like to put a petcock in instead of a plug though, makes it a lot easier to drain the block.
Old May 16, 2006 | 07:29 PM
gcore45's Avatar
Car: '91 RS
Engine: 5.7 tbi
Knock Sensor!!!!! Ah-hah. I didn't think there were two plugs when I stripped it down. I just have to find the knock sensor now. At least that will be easier to search for at the parts store if I come up snake-eyes.
Lesson learned. Label parts better!!!
Old May 16, 2006 | 08:55 PM
gcore45's Avatar
Car: '91 RS
Engine: 5.7 tbi
Doesn't the knock sensor screw into the head?
Old May 16, 2006 | 08:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, into the drain hole in the block. The temperature gauge sender screws in the the LH head, the fan switch screws into the RH head. The threads on the knock sensor are much too small for the coolant ports on the heads.
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
Mickeyruder
Sep 2, 2015 02:45 PM
camaro71633
Sep 1, 2015 10:24 AM
theurge
Aug 21, 2015 12:46 PM
