Fuel pump and starter questions
Old May 18, 2006 | 02:25 AM
Camaero's Avatar
Car: 1987 IROC Z/28 Camaro
Engine: 355
Axle/Gears: 9 Bolt w/ 4.10s
Hey guys, just looking for some advice here. For my 350 I am getting ready to put in which should crank out around high 300 to 400 HP, what fuel pump and starter would you suggest? I am looking to get as light as possible on both of them.
Old May 18, 2006 | 02:30 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Starter: aftermarket mini starter. For a while I had a CVR and loved it, got a Tilton, love it even more. Highly recommended. Depending on what year block, you may get away with an LT1 mini starter. Other companies like Powermaster make high torque mini starters as well.
Fuel Pump: depends on application, EFI, carb?
Old May 18, 2006 | 12:49 PM
Camaero's Avatar
Engine: 355
Thanks for your suggestion! That Tilton looks pretty good. I checked it out in Summit.
I will be running my TPI for now but later might upgrade to a SR later if that matters. Let me know some suggestions on that.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
