still nothing
Old May 25, 2006 | 08:17 PM
slimstyle's Avatar
Car: 1990 chevy camaro rs
Engine: 305,v8
Transmission: auto
still nothing
i washed my engine bay two weeks ago and now it wont start. i turn the key and nothing (not a sound). the battery is brand new. the radio stopped, the door buzzer stopped, and the instrument panel died. i need help. i still have good power everywhere eles.(headlights,hatch release, and dome light.
Old May 25, 2006 | 09:04 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
im not good with elic. problems but....i think there is a small wire running from the positive battery post check it...i think it also has a fuseable link...if nothing else i bummped you back up...good luck tao
Old May 25, 2006 | 10:41 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Check your fuses, not a genious with electronics here, but since you have SOME electronics that work, it tells me that your battery isnt fried, obviously.
Old May 26, 2006 | 12:39 AM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Transmission: NV4500
Axle/Gears: 4.10
Check the fusible links from the starter solenoid as well...
