Best type of spark plug & wire set up?
Old May 27, 2006 | 01:07 AM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
I have a standard set of AC plugs and MSD Cap n' Rotor , and MSD 8.5mm Plug wires is there a set up better than this?
also while im here the MSD COIL and POWER box are any good ?
Old May 27, 2006 | 02:34 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
sounds fine to me. i just run typical borgwarner cap n rotor cuz its all the same copper contacts. the box (6a or 6al) is good for its multi spark and better faster starting and mpg increase.
Old May 27, 2006 | 09:08 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
If you've already got that setup then stick with it. If you were to get a different setup I would say to go with a set of Moroso cut to fit wires and some NGK plugs. The Moroso wires seemed to hold up better than the MSD's and the boots are better. They're a little smaller so they clear headers better and they also fit the plugs tighter for better contact.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
apo_bailon15
Mar 28, 2016 05:20 AM
