Trouble Code 33 on 89 GTA w/350
Old May 28, 2006 | 04:26 PM
jgrist63's Avatar
The Service Engine Soon light on my 89 Trans Am GTA has been coming on. The stored trouble code is 33 - the FAQ section indicates that is a High Voltage (low vacuum) at the MAP sensor. If the car is at idle or low RPM, it may run very roughly or even stall. The idle/stall problem doesn't seem to occur if the car is at a crusing speed. Before I could get a valid trouble code, I had the spark plugs, plug wires, and O2 sensor replaced. Is there a common cause for this code or is it one of those codes that could be caused by a thousand different things? Thanks!
John
Old May 28, 2006 | 04:34 PM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
even the slightest crack in a vacuum hose for map will **** it off triping a code check ur hoses for heat rot or cracks specially hoses under the TPI pendlium
Old May 28, 2006 | 04:43 PM
jgrist63's Avatar
Don't think it's that
At first glance, the vacuum hose looks fine. I guess there might be a pin hole or smething but there's nothing obvious
Old May 28, 2006 | 05:24 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Your car is an 89, it does not have a map sensor. Code 33 is a mass air flow sensor code. First thing I'd be looking at is the maf power and burn relays. Thier located on the firewall between the d/s fender and brake booster (the 2 oval ones).
Old May 28, 2006 | 06:21 PM
jgrist63's Avatar
What do I need to look for on those relays?
Old May 28, 2006 | 08:21 PM
The relays are about 12 dollars at most parts stores I'd replace them both, also inspect the condition of the wiring on the connectors, any bare spots should be wrapped with elec tape.
Old May 29, 2006 | 08:59 PM
jgrist63's Avatar
I replaced the relays - cost me $15 and took 10 minutes. The first results are encouraging. I drove it all afternoon in 95 degree heat with A/C blasting and lugging it to the mall, Target, etc. without any sign of the Service Engine Soon light.....
Keeping my fingers crossed
John
MantyZ28
Nov 8, 2015 06:54 PM
machinist21
Sep 5, 2015 03:03 PM
RyanJB
Sep 2, 2015 01:27 PM
