What happens if the rockers are too tight?
Old May 31, 2006 | 08:51 PM
StrokedZ28's Avatar
Car: 86 Z28
Engine: 383
Transmission: Built 700r4
When I replaced the heads on my car I tried to set the rockers to have zero lash. I interpreted this from the chiltons manual as meaning that the pushrods should be snug and you ca't move or twist the pushrods anymore.
Now I here that if you overtighten them that there can be problems. Is that true and how do you know that you did?
Old May 31, 2006 | 08:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The valves will lift off the seats and stay open.
Old May 31, 2006 | 08:55 PM
StrokedZ28's Avatar
Car: 86 Z28
Engine: 383
They would stay open? Without the rocker pushing the spring down would they remain closed?
Old May 31, 2006 | 09:18 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's the idea.
Old May 31, 2006 | 09:34 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Hydraulic lifters use zero lash but also have a preload inside the lifter. You adjust the rocker until the pushrod becomes snug without overtightening to push down on the pushrod. Then tighten the rocker down an additional 1/2 turn to set the preload. After setting the preload, the lifter will bleed down and the pushrod won't be tight any more. That's normal and just how hydraulic lifter work. Don't tighten it any more.
With a solid cam, you always have valve lash. If tightened to zero lash, the valve will never close onto the seat.
Ed1LE
Sep 30, 2018 09:14 AM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
