Car hesitates - Fuel problem?
Old Jun 4, 2006 | 12:04 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
Engine: Holley MPFI, AFR 195, Hot Cam=375HP
When ever my car gets a to full temp, about ut 210, it starts to cut out. It happens during light throttle at first. I put my foot in it a little and it smooths out. But I cant drive around around live Im at Daytona all the time. Eventually the car gets real warm and does the same thing during hard throttle too.
The pump is a Walbro 255 unit with less than 50K so I dont think thats it. FP filter has 20K, might just replace that for fun.
I know I need to check the ground on back of the engine. Might be loose.
It could be the FP Relay right? Might replace that just for fun.
Also I thought about checking the voltage at the connector between the back seats. I could back probe em and check what my voltage is while driving. There are three wires. I want black and red right? Whats the third one for, I think its green?
Any other suggestions?
Old Jun 4, 2006 | 12:11 PM
manchesterbeast's Avatar
Car: 1985 pontiac trans am
Engine: 350 with carb and headers
Transmission: borg warner 5speed
more info would be better. my guess at this point is maybe your running rich.
Old Jun 4, 2006 | 12:24 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
What other info do u need?
I have 91 RS with 96 truck block, afr heads, hot cam and Holley MPFI Intake.
I use 36lbs inj. and a walbro 255 pump. Rest of fuel system is stock.
Ignition is stock except for good wires and a DUI dizzy.
I think it smoothes out when my foots in it because the Fuel Reg gives it a couple extra psi and my alternator cranks out a few more amps. My voltage meater says I have 13.4 volts at idle, but I dont know if that changes while driving. The voltage guage in the car isnt very accurrate.
Old Jun 4, 2006 | 12:55 PM
you edited your original post. you had very little information posted before.
Old Jun 5, 2006 | 12:34 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
So am I on the right track?
Can someone idetify the FP wires for me?
Ghettobird52
Jul 5, 2024 11:18 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
