Need help
Old Jun 7, 2006 | 10:25 PM
falcon54's Avatar
Need help
I have a 1983 Z28 Camaro. I recently went through my engine and put new seals in it. While doing that I decided to add a single plane intake. Now it smells like it's running to rich. I have a stock quadrajet carb.
I tried adjusting the bleed air valve(I think that's what it is called) and I can't get the gauge above 12 where as I need it at 30. Any suggestions?
Old Jun 7, 2006 | 10:34 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
im kind of curious as to why you would put a single plane intake on your car...
Old Jun 7, 2006 | 10:37 PM
falcon54's Avatar
Just trying things out. I'm seeing what i want when I buy a new engine for it. Never used a single plane before so, wanted to see what all it would do performance wise.
Also my duel plane is slightly cracked. Had the single plane there.
Old Jun 8, 2006 | 07:07 AM
falcon54's Avatar
Sorry for double post. It's the idle air bleed I adjusted not what I originally said.
