oil pressure...problem?
Old Jun 8, 2006 | 02:44 AM
riphc06's Avatar
Car: 89 Camaro RS
Engine: 350 TPI L98
Transmission: 700r4 w/ shift kit and 2500 stall
Axle/Gears: 2.77 one tire fire!!
My stock oil pressure gauge is reading just below 60 at idle and above when accelerating. First of all is there such thing as too much oil pressure? Second of all is this a result of a high volume oil pump? Could it be the viscocity of the oil im running? Thanks for any help.
Old Jun 8, 2006 | 03:19 AM
ede's Avatar
ede
you have a mechanical gauge? if not i wouldn't put a lot of faith in the gauge, even so your numbers don't sound bad.
Old Jun 8, 2006 | 09:36 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Is their such thing as too much pressure?
I think the sending unit has gone south on ya if its a elec gauge.
If its mechanical, maybe something clogging up the bypass.
Old Jun 20, 2006 | 01:09 AM
riphc06's Avatar
Car: 89 Camaro RS
Engine: 350 TPI L98
yea its an electric gauge....ill look into a new sending unit and see if that solves the problem....thanks for the help guys....any other ideas are welcome
Old Jun 20, 2006 | 07:50 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
what is the preasure when it is fully warmed up at idle?
Old Jun 24, 2006 | 04:17 PM
riphc06's Avatar
Car: 89 Camaro RS
Engine: 350 TPI L98
depending on the wheather, it sits in between 60 and 30 at idle....usually it is around 50
Old Jun 24, 2006 | 04:23 PM
camarogirl91's Avatar
Car: 1991 Camaro RS
Engine: 305 V8 5.0 liter(right now!)
Transmission: 700R4/ 4l60E
Axle/Gears: stock
My car runs at 30 at idle and driving its between 50- 60 so i think your in the right range. Hope this helps some
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
