Disconecting the MAP sensor
Old Jun 9, 2006 | 05:00 PM
v vet 1967's Avatar
Car: 89 trans am gta
Engine: 5.7
Transmission: auto
89 GTA 5.7 TPI. I had stalling problems and the car would die after a few seconds of running. I disconected the MAP sensor and turned the key and it fired right up with no problems detected. Runs like a champ.
My questions is do I need the MAP sensor? Can I keep it disconected without any mechnical problems and save $180.00
BTW, thanks to all those who gave me hints on the problem I had.
Old Jun 9, 2006 | 05:11 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
You won't have any "mechanical" problems with it disconnected. You will have some mileage issues and a check engine light with it disconnected. I don't know where you got your price from but $180 seems way high for that.
Old Jun 9, 2006 | 06:47 PM
brutalform's Avatar
Are you talking about a MAP, or MAF? On an 89, you should have MAF, unless it was converted to S/D. Then, it still would be expensive for a MAP sensor.
MAP=manifold air pressure
MAF= mass air flow
Old Jun 10, 2006 | 10:28 AM
v vet 1967's Avatar
Engine: 5.7
Transmission: auto
Mass Air Flow Disconnect
I looked up the price at autozone and advanced auto parts and it was $180.00. Its the part that is in between the intake manifold and the air cleaner. I was told that it can be cleaned but using some type of chemical cleaning agent.
Old Jun 10, 2006 | 02:21 PM
1981LT1's Avatar
Engine: LT1; LT1
That would be your MAF, not MAP. You are talking about the Mass Air Flow sensor. And yes, you need that to run properly.
Old Jun 11, 2006 | 09:50 AM
v vet 1967's Avatar
Engine: 5.7
Transmission: auto
maf
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
efiguy
Sep 27, 2015 01:30 PM
