radiator hose
Old Jun 10, 2006 | 10:04 PM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
radiator hose
I am looking for a radiator hose for my car with the new carb engine. is there a stock radiator hose i can use for my setup or what car could i get one from that would fit this radiator neck. but if there is not a stock one i can get for this neck if i buy one that turns to the right what car could i get one off of then. thanks
Old Jun 10, 2006 | 10:46 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
if you get a 45* waterneck, you can use the hose meant for a '82 camaro V8 I think. Unless you've got a different upper fan shroud or something that would throw a wrench into that plan.
that's a straight waterneck, so i'd think you could use a rad hose meant for a car with a straight water neck.... maybe an '84 chev truck, 350 motor. The only thing to watch for, is....is the rad the same distance out from the motor?
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
