Some easy questions for you guys!
Old Jun 11, 2006 | 09:14 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Are 305 connecting rods the same as 350?
is the 305 crank the same?
Old Jun 11, 2006 | 10:14 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Rods are the same I Know,I believe that the cranks are the same,but I'm not absolutely positive.I know the stroke is the same,not sure on the counterweights.
Old Jun 11, 2006 | 11:58 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
the crank weights are wrong, so it wouldn't be balanced.
I'm also pretty sure the rods would work.
Old Jun 12, 2006 | 11:59 AM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
The rods are the same, but as sonix said the crank is balanced totally different from the 350. They share the same stroke and bearing sizes, but that's all. The weights of the pistons totally change the balancing process.
MustangBeater20
Oct 29, 2022 09:20 PM
customblackbird
Aug 15, 2021 10:16 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
redmaroz
Aug 16, 2015 11:40 PM
Street Lethal
Aug 14, 2015 08:25 PM
