Fuel Pulsator
Old Jun 12, 2006 | 09:04 PM
kmath's Avatar
Car: 89 Iroc
Axle/Gears: Ford 9" 4:30 gears
Fuel Pulsator
I'm now about to replace the Fuel pump in my car and someone from Autozone said I should put a Fuel Pulsator in with the new pump that will prevent fuel starvation in the event of vibration.This is an AC/Delco part.Anyone heard of this?
Ken
Old Jun 12, 2006 | 10:21 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Most people just leave off the pulsator and use a short piece of high pressure rubber hose instead. There will be no problems doing it like that.
Old Jun 13, 2006 | 07:06 PM
kmath's Avatar
Car: 89 Iroc
Is it safe to assume this is a factory part,or something recommended to fix a factory problem.
Old Jun 13, 2006 | 07:13 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
The pulsator valve absorbs the shock of the injectors pulsing, helps to provide an even, more steady flow at the fuel rail. Your car will probably run fine without it but if your going to pull the pump anyway, it couldn't hurt and it's not that expensive of a part.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
