copper flakes in my oil
Old Jun 16, 2006 | 02:01 AM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
I changed my oil today and noticed that while the old filter was draining in my catch pan there was a fine, copperish, looking dust in the oil. Is this bad?
I may have not noticed it before because this is the first time i changed the oil at night using a trouble light. It glistened and left a copper glittery trail in my catch pan. It looks like very fine copper glitter.. I am using Mobil 1 full synthetic and have been changing the oil every 3k or less since 1997...
Old Jun 16, 2006 | 02:49 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Main or connecting rod bearings.... How's your oil pressure?
Old Jun 16, 2006 | 03:06 AM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
oil pressure is good. usually 50-60 on start-up and 30 when warmed up. It climbs to at least 40 when im on the throttle and its warm.
Old Jun 16, 2006 | 07:49 AM
Vader's Avatar
Copper or bronze? About the only sources of copper in the engine may be some plating on bearing shells. Bronze may be from a distributor bushing. Since your signature lists "Stock engine" it's not likely to have a bronze distributor gear, unless you've changed that. There just isn't that much used in a stock engine.
Old Jun 16, 2006 | 11:29 AM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
distributor is stock. I did put an additive in my last oil change (before i found out additives were bunk) I put a can of restore in it. Maybe its from that crap.
Im not too worried about it since the car runs great and im going to flog it until destruction. Im going to the track tommorow with 2 bottles of laughing gas. Im gonna try a 200 shot and hope for an 11.99 or better.
Old Jun 16, 2006 | 11:35 AM
wrightz28's Avatar
Car: '88 GTA,'85 z28
Engine: L98, LB9
Transmission: 700 r4
Axle/Gears: sleepy 3.23, hello 3.73
Originally Posted by 2QUIK4U
) I put a can of restore in it. .
did that once, coincidently a week later it threw a connecting rod right through the side of the block.
jrdturbo
Mar 31, 2016 02:58 PM
88CamZ
Oct 8, 2015 10:29 AM
skinny z
Oct 5, 2015 06:23 PM
mfp189
Sep 27, 2015 09:25 AM
