car jerky at low speeds
Old Jun 23, 2006 | 08:17 PM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
ever since i put my 350 i can be at a stop and start going and just holding my pedal down to accelerate alittle it starts jerkin,but if i give it alittle extra gas it`s fine or of get on her she`s fine. l am lost with ideas
Old Jun 23, 2006 | 09:10 PM
Johns1989irocz's Avatar
Car: 1989 Iroc
Engine: 5.7L 350 TPI
check your throttle position sensor, in my 89 iroc i had a similar problem and i replace my tps, and ever since the car runs great. the tps is on the pass side of the motor right in fron of the throttle body, at least that is where it is on my 350 tpi. there is a wire clip going to it, pop that off and remove the 2 hex head screws (might be phillips head also) reinstall the new one in reverse order plug in and go. It could also be your computer.
I hope this helps
john
customblackbird
Aug 15, 2021 10:16 PM
B_Dubya
Aug 26, 2015 05:09 PM
kyleb24
Aug 15, 2015 08:24 AM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
