I'm pulling my GTA out of long-term storage, and...
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Like the subject says, I'm pulling my GTA out of long-term storage, and would like to get opinions on what I need to do before cranking it over for the 1st time. Like a dummy, I haven't cranked it over for about 18 months, so I'm a little bit concerned about what I need to do to make sure that the rings don't scuff the cylinder walls on initial startup. Not sure if WD-40 is too light, or...?
Here's my "to-do list" that I'm working against (and here's another that I found while searching), if anyone has any suggestions, I'd definitely like to hear them...
Thanks all.
Thanks all.
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Originally Posted by Psycho_91Camaro
just crank it!!!!
Car: 1987 Trans Am
Engine: tree-fiddy
Change the oil for one thing.
Pull the plugs and put a little oil in each cylinder and rotate the crank a few times around to get the oil in the rings.
Basically if there was a liquid in the car, flush it and put new oil/trans fluid/gas/coolant in the car. It's cheap and easy to do and will give you peace of mind. Once that is all done, make sureyou have a good battery and crank her up.
<<- Misses his GTA.
<<- Misses his GTA.
Pilotrick50
Sep 2, 2015 12:48 PM
NBrehm
Aug 5, 2015 07:57 PM
