another is my motor locked up question
Old Jul 2, 2006 | 02:10 PM
raptor80dad's Avatar
Car: 92rs
Transmission: 350
Axle/Gears: 3.73/Moser 12bolt
ok i've done a search & havent seen anything exactly like my problem.
went to track today and after the last run i shut the car off for a few minutes then my nephew started it drove to the lanes and shut it off.sat for app. 10 minutes went to start it & no deal .starter move the motor maybe 100th of a turn & started making a grinding noise.now that is all it will do.
I tried to turn it by hand & no deal crank bolt actually started to turn so I quit
I read about the hydrolock but it seems everyone was driving when this happened.could this be it?
Old Jul 2, 2006 | 02:18 PM
88blkbird's Avatar
Car: 88 Firebird
Engine: 5.0 ltr
Transmission: 4L60
Axle/Gears: 10bolt 3.23's I think
difficult to tell, it's possible.. best solution is pull all the plugs and crank it.. if water comes out you'll need to pull the head on the offending side. if it still doesn't turn you either have a starter problem or a worse engine issue.
Old Jul 2, 2006 | 02:24 PM
Car: 92rs
Transmission: 350
yeah I will pull the plugs asap it is . 100 degrees out here & been at the track all day till now so I figured I would let it & me cool off.
just seems weird it could lock up when off
Old Aug 5, 2006 | 06:36 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
I just had an engine hydrolock on me. I couldnt get the car started and replaced all the wires an plugs and it started right up but it was blowing white smoke. I turned the car off tried to restart it but it locked up on me. It didnt even turn more that twice before it locked up. Not sure what kind of damage it does when you hydrolock an engine while trying to start it. I plan on ripping off the heads and dumping tranny fluid or oil down the cylinders and letting it sit and then try to get it to crank. I guess I wont know what kind of damage it did till I get the heads off. Anyone have any experience with this? Its my wifes car so I didnt know what to expect.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
MustangBeater20
Oct 29, 2022 09:20 PM
redmaroz
Aug 16, 2015 11:40 PM
