Distributor
Old Jul 9, 2006 | 05:02 PM
Iroc Adio's Avatar
Car: 1987 IROC
Engine: Destroked 377
Transmission: TH-400
Axle/Gears: 9inch with 3.70's
Distributor
Im having some trouble with timing my car. I have the MSD 6al box, blaster 2 coil, and MSD pn 8361 distributor. When my car is idling (900) my timing says 27* with the vac advance disconnected. It seems to run fine like that. But it shouldnt be that high so i try to bring it down to 10* but then motor runs weird. I will tap the gas and the rpms will go up way to easy. Can anyone help? Thanks
Old Jul 9, 2006 | 11:53 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You should be able to lower the idle speed below 900RPM... Also, 27*, with that cam, and your compression ratio and whatnot, sounds fine. More duration needs more timing at idle.
Which springs are in the distributor? Maybe the advance is coming in at idle, making it unstable.
Are you running manifold or ported vacuum advance?
Then finally, shoot for ~32* timing at 3500RPM. Adjust for that. Then bring it back to idle, and let it be at that timing. Use manifold vacuum advance timing if you need more timing at idle to get it to run right.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
