Torque Specs for LT1 heads.
Old Jul 22, 2006 | 01:42 PM
IROCZ86's Avatar
Car: 96 SS #15
Engine: LT 1
Transmission: M6
Axle/Gears: 3.42 ZT
I need the Foot pounds and the pattern to bolt down Aluminum LT1 heads.
If you dont know were to go to find it would help. I,m not buying a book.
Old Jul 22, 2006 | 01:58 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Head bolts are 65 ft lbs and intake is 35 ft lbs. Make sure to use the tightening sequence on both the intake and head bolts starting in the middle and working your way out in circular sequence. I always did a three pass tightening sequence on the head bolts. 25 ft-lbs first on them, then 50 ft-lbs on them and finally 65 ft-lbs pounds. That's how I was taught and had no problems.
L0tuS
Oct 4, 2015 08:07 AM
New2Chevy
Sep 28, 2015 12:35 AM
ericjon262
Sep 11, 2015 06:07 PM
angel2794
Sep 8, 2015 06:22 PM
