3.4 a success but not going into gear
Old Jul 23, 2006 | 12:03 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
Axle/Gears: limited slip posi 3.42
well like i said my 2.8 to 3.4 swap was a success and the guy who posted the one thread and passed away have done it several times and only made it work a couple times so for my first engine swap i would say i did pretty good but just one promblemo it won't go into gear at all i can puit it into gear then start the car then it will go but i won't be able to get out of the gear or go into another one also when the clutch is down and i hit the gas i move a bit just a biut but still noiticable that it's not supposed to be doing that i took off my old slave cylinder cause the plastic lip broke so i got a new wagner one that's cast iron or some other type of steel maybe i just need to bleed it better or if anyone has any ideas to check for certain things that could be wrond b4 takin my tranny off to get to my bellhousinf to check that out cause the fork is moving on gear i looked threw the boot where the fork is but ya any ideas or questions would be appriciated.
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
georgiaslim45
Sep 9, 2015 08:11 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
