abnormal lifter wear?
Old Jul 23, 2006 | 04:41 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
I pulled the manifold off for a leak and checked all of my lifters while I was there (a lot of horror stories out there). Got about 2-3 hours on the motor after a cam change (comp cam and lifter set XE 256). Each lifter shows a small scuff mark in the center with barely discernible spiral marks from the center out with a small scuff ring around the perimeter. Is this normal wear on the way to a lifter with a polished face? I've pulled lifters out before but never this early in the break-in.
Old Jul 23, 2006 | 04:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Is it still convex?
Old Jul 23, 2006 | 05:24 PM
That's OK.
That one has been turning. That's why it looks uniform all the way around. What you DON'T want to see, is a little "bar" looking shape of wear, where the cam lobe has never run on any other spot except that "bar".
Old Jul 23, 2006 | 05:31 PM
naf's Avatar
naf
Thanks for the replys. Still convex. I felt 90% safe seeing the same pattern of wear on each and evidence of the lifter turning. Just used to the shiny, mirror like finish on a lifter with many more hours on it I guess.
Course I wouldn't have even pulled them to look if not for all the bad press lately on failed cams.
Old Jul 23, 2006 | 08:37 PM
Damon's Avatar
As long as it's still slightly convex a normal wear pattern would have just a tiny "halo" of untouched metal around the outer 1/16" of the lifter face. The center will look rather "cloudy" from being poished at different angles by the cam lobe as the lifter spins.
codeysabatini
Nov 10, 2015 04:07 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
skinny z
Oct 5, 2015 06:23 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
dimented24x7
Sep 6, 2015 03:51 PM
