compression
Car: 1970 GMC LWB Street strip
Engine: 383 stroker
Transmission: 350TH
Axle/Gears: 12 Bolt 4:11
compression
Can anyone tell me if i can test compression ratio with the motor assembled. I didnt build the motor and dont know truely whats inside, but i would like to find out compression wise. Is there a way. if so, how do i do it. thanks
Sure.
Put a starter and a flex plate on it and whirl it over.
Won't tell you much necessarily, since the lifters may or may not have any oil in them, or some might have some and some not.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You can do a compression test like sofaking says, but you can't measure the compression ratio. You'd have to take it apart.
WhteRbt
Sep 21, 2015 09:48 AM
