fuel pump alway running when ignition is on
Old Jul 31, 2006 | 09:07 PM
camaro350tpi's Avatar
Car: camaro iroc-z 89
Engine: 383 HSR SC MegaSquirt
Transmission: tko 600
Axle/Gears: 9 Inch 3.75
HI, I HAVE A CAMARO 89 350 TPI , WHEN I PUT THE IGNITION ON THE FUEL PUMP ALWAYS RUN , NORMALY IT RUN ABOUT 10 SEC BEFORE SHUTTING DOWN BUT NOW IT ALWAYS RUNNING SOME ONE HAVE AN IDEA !? ILD PUT A NEW FUEL PUMP RELAY AND IT DOESNT CHANGE ANYTHING...
Old Jul 31, 2006 | 09:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Check the oil pressure switch.
Old Jul 31, 2006 | 09:15 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
My friends did that. As long as you keep fuel in the tank to keep it cool it will be fine.
Old Jul 31, 2006 | 09:21 PM
where is the oil pressure switch, you have a idea ?
Old Jul 31, 2006 | 09:26 PM
Old Jul 31, 2006 | 09:34 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
oil pressure switch should be right above the oil filter.
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
