Hessitate,stumble, stall..
Old Aug 1, 2006 | 09:46 PM
AcedRaven's Avatar
Car: 1987 Firebird Formula
Im having a problem with my carbed 305 87 formula, my timming is set at about 7-8*.It idles fine but when putting the car on a load it will stumble if I keep the gas pedal down it will stall. I kinda havet to ease it from a stop to get it going. Any ideas what i should be looking for to fix this problem? Ive been looking to make sure all the vacume lines are hooked up and cant seem to find anything wrong.
Old Aug 2, 2006 | 03:45 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Could be a clogged fuel filter, could be choke sticking or not set properly or could need a good tune up. Also have you checked for any codes??
Old Aug 2, 2006 | 10:54 PM
AcedRaven's Avatar
replaced the fuel filter a few weeks ago. The car has been tune up within the last 2 months (new spark plugs,wires, dist cap, rotor, thermo, oil changed..etc). The choke does seem to have a stick to it when moving it by hand but from what ive read that after the car is at normal running tempature the choke stays open? The car will do this all the time (not only when cold) as for codes it wasnt throwing any, yesturday I got a code 44 tho.
Old Aug 2, 2006 | 11:35 PM
AcedRaven's Avatar
also When i got code 44 it was on the highway and it seemed to have a lack the faster i went the longer it seemed for it to kick in and go.
Old Aug 3, 2006 | 11:00 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
Have you tried an O2 sensor yet?..it does have one doesnt it?
Old Aug 4, 2006 | 01:34 PM
AcedRaven's Avatar
Yes, it has one.. I put a new one in about a month ago. Im going to try and swap the old one back in and see if that changes anything.
Old Aug 8, 2006 | 10:52 AM
AcedRaven's Avatar
anyone?
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Logan Bryant
Sep 23, 2015 06:51 AM
RedLeader289
Sep 23, 2015 06:50 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
