Got a new oil pan...got some ?s
Old Aug 1, 2006 | 10:07 PM
BT283's Avatar
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
Okay here is the deal, i bought a new oil pan for my 355 and it came with a new pick up. So i put the new pick up tube on the new oil pump, and the oil pan WILL NOT clear, i mean there is no possible way, because it hits the baffles inside the oil pan. so i put my other oil pump in with my stock pickup tube and it will not even clear the windage tray. so here is the question, can i cut the baffles out of the oil pan, and if i do so i will also no longer have a windage tray, will this be fine or will i need a windage tray? thanks
Old Aug 2, 2006 | 12:27 AM
LLLosingit's Avatar
If you were a little old lady driving a caddy I would say you could do without a windage tray but in your case I would do whatever it takes to keep the windage tray, It's there to keep the oil pump fed with oil under high G- loads..Braking, turning ect.
It also keeps the oil down low in the pan and not up where it can get whipped to death by the crankshaft.
I would either contact the manufacturer or replace or reuse the old one.
Old Aug 2, 2006 | 12:33 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Which oil pan, pump and windage tray are you using?
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
