sound like a timing issue?
Old Aug 5, 2006 | 04:18 PM
Syn's Avatar
Syn
Car: 1989 Formula Ws6
Engine: 305 tpi
Transmission: 5speed
well i just got done doing my lim gasket and i didn't use a timing light yet cause i wanted to see if it would leak anywhere when started but when i start it, sometimes it stalls but usally it just idles real low like it has a cam or somehting then all assuden the idle will jump like i gave it throttle
i am thinking timing
anyone else?
i should have the timing likght tomorrow
Old Aug 5, 2006 | 05:14 PM
mark wells's Avatar
Car: 85 Trans Am
Engine: 383 ci
Axle/Gears: posi 342
Sounds like your IAC motor is clogged. The IAC motor regulates the air going into the car at cold start. Remove the IAC motor and clean it. I removed my throttle body and IAC motor when I had the same problem and cleaned both. That took care of the same problem in my car. estimated time and cost. 45 min and $3.50 for throttle body cleaner.
Old Aug 5, 2006 | 07:21 PM
Syn's Avatar
Syn
Engine: 305 tpi
i was thinking it wouldn't be the iac cause the car ran liek a champ a few weeks ago before i tore it down to do the intake gasket. i left the t/b and everything connected to the plenum.
but i guess i can try something
also i am getting no codes yet
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
TheExaminer
Aug 19, 2015 10:07 PM
86Base
Aug 8, 2015 01:34 PM
