91 tpi to carb?
Old Aug 8, 2006 | 05:48 PM
fg_stadium's Avatar
91 tpi to carb?
thinking about switching my 91 305 z28 to a 350 carbbed,can I leave the intank fuel pump in but not useing it and use the onblock pump?
Old Aug 13, 2006 | 08:26 AM
Vader's Avatar
Try a SEARCH. I believe it's been attempted, but am not sure of how successful those attempts have been. Another method is to use the in-tank pump and add a 3-line regulator (with return) to hold fuel presure to 5 PSI or less.
Old Aug 13, 2006 | 04:52 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
If you want to use the pump in the block it is best to remove the pump in the tank. The block pump cannot suffiently pull gas through the in tank pump.
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
