fuel pump question???
Old Aug 8, 2006 | 08:58 PM
fg_stadium's Avatar
I have a 91 z28 305 tpi that I'm putting a carbbed 350 in and bypassing the computer and I was wondering if I keep the in-tank fuel pump in but dont use it if the block-pump will suck fuel to the carb?I dont want to have ta drop the tank
Old Aug 8, 2006 | 09:12 PM
Bowtye101's Avatar
Car: 1991 RS/ 2006 Charger R/T SRT-8
Engine: 383 4bbl / 6.1 liter HEMI
Transmission: TCI 700R4
Axle/Gears: 3.42 posi
Fuel Pump
that pump has far to much ppressure for a carb, you will either have to put a good fuel pressure regulator in line or even better and cheaper take it out and use an in-line fuel pump that puts out 4.5 to 9 psi or less.
Old Aug 8, 2006 | 09:16 PM
fg_stadium's Avatar
I'm not going to use the in-tank pump,I was just going to leave it there and use the fuel pump on the block,I just dont know if that pump beeing in the tank will block the fuel from going to the carb
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
