base timing for LG4 after computer removal
Old Aug 20, 2006 | 03:50 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
what would be the recommended base initial timing setting for an LG4 with non computer carb and HEI swapped on it
also what if you cant find a port on the carb that is not pulling vacuum at idle speed
what shoul you do then,
i see it as being a problem because when you connect the vacuum advance to a source thats pulling at idle hen it will advance your initial setting
can someone explain something here ?
i am probably just over -complicating or over-looking something here
thanks
Old Aug 24, 2006 | 09:01 AM
Vader's Avatar
At least 4-6° BTDC is a good starting point, but experimenting with timing will usually yield the best results.
As for the timed vacuum port, there is usually at least one on a 4MV. However, if the throttle stop screw is opened too far (high idle setting) the port will have some vacuum. If you are planning to use this for a vacuum advance unit, it may not matter a lot. Set the timing with the vacuum line disconnected, then connect the vacuum advance. It's quite the same as setting the base timing on an HEI/EST system withe the EST in bypass, then connecting the EST. The idle timing advance will usualy jump to near 25° with the EST active, just like connecting the vacuum advance unit. think about how they work and why, and you'll understand why the extra advance at idle is not a bad thing.
RazorN8
Jan 7, 2022 11:44 AM
Vintageracer
Jan 10, 2020 05:33 PM
perZ
Aug 15, 2015 01:17 PM
Thirim
Aug 9, 2015 06:19 PM
3rdgenparts
Aug 8, 2015 07:09 PM
