need help 95 z28
Old Aug 23, 2006 | 05:09 AM
speedy15464's Avatar
need help 95 z28
Im having a problem with a 95 chevy camaro z28
i recently installed taylor 8mm spyro wires and ngk tr55 plugs. the reason for this was i am getting spark at the plug boots itself on #8,#4 #3 and around my coil . i replaced my cap and rotor too with an accel from summit. what would be causing this i tried 4 different sets and changed the coil too no difference . cleaned the boots and used dielectric grease and cleaned and checked all grounds it still does the same. is this common or did you ever hear of this and what else could i check
Old Aug 23, 2006 | 05:43 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Since this is your first post, you may not realize that this site is designed for thirdgen (82-92) vehicles. CamaroZ28.com might be a better site to more fully investigate your 95.
JamesC
starliner
Feb 9, 2016 08:18 PM
blackz281le
Jan 11, 2016 07:51 AM
David Frans
Oct 31, 2015 08:12 PM
Night rider327
Oct 9, 2015 09:25 AM
z28joe2
Sep 28, 2015 05:54 PM
