question
Old Aug 27, 2006 | 12:05 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
question
when my car is hot, its very hard to start my car, i have a 86 camaro z28. 81 350 motor, supartine belt system, i have a new battery and alt, dont its very hard to start, what can be the problem
Old Aug 27, 2006 | 01:22 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the problem could either be vaporlock or a bad starter
Old Aug 27, 2006 | 01:24 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
whats a vaporlock
Old Aug 27, 2006 | 02:44 PM
ede's Avatar
ede
does it turn over and not start? since you referanced the battery and alt. i'd guess that is the case, if so you need a new starter, don't confuse new and rebuilt. vapor lock is when the fuel becomes more vapor than liquid and can't be pumped. if you have an electric pump vapor lock isn't your problem, unless you wrapped a line around a header tube.
Old Aug 27, 2006 | 02:57 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
yes it will turn over but wont start , try and try again it will start
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
