how do I adjust rocker arm/valve?
Old Sep 1, 2006 | 12:27 AM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
this must have been mentioned before.. but Ive manually browsed through a bit,
and used some search but i cant seem to find what im looking for..
how hard is it to adjust rocker arm? caz I think mine could be loose or something.
I know its something like using the valve overlap to find the TDC cylinder,
and torque the TDC to certain torque and turn it back 2times or something like that..
is this what it takes to adjust my valve?
if so where can I find torque spec for a 91 RS v6?
and when i manually turn the crank,
it wont screw my ignition timing will it?
Im such a noob but I wanna tackle this procedure.
any help is greatly appreciated
Old Sep 1, 2006 | 12:56 AM
9ronone's Avatar
Car: 88 Iroc; 98 ZX9
Engine: TBI350; 998cc
Transmission: 700r4; 6speed
Axle/Gears: 3.42posi; several sprocket sets
Valve Adjustment Procedure
I know this is for a v8, but converting it for your 6 shouldn't be too difficult. Hope it helps!
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
loud91rs
Oct 5, 2015 10:05 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
