Help!!
Old Sep 1, 2006 | 06:29 AM
91GTAWS6's Avatar
Car: 91 Trans Am GTA
Engine: 305 (310)
Axle/Gears: 3.73's
Help!!
Looking for some suggestions here... I am having to turn my key on and off about 3-5 times before my fuel pump cuts on.... i noticed this a few days ago when the car didn't start on the first try. if anyone has any ideas please let me know. possible fuel pump going out???
Old Sep 1, 2006 | 06:45 AM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Could be the fuel pump relay
Old Sep 1, 2006 | 07:27 AM
j dezzy's Avatar
Car: 87 TA
sounds like maybe a VATS problem...
Old Sep 1, 2006 | 03:01 PM
91GTAWS6's Avatar
Engine: 305 (310)
Axle/Gears: 3.73's
i'll swap out the relay and see what happens.... VATS only disables injector pulses on my car. already had a run in with that. haha. thanx fella's
Old Sep 1, 2006 | 03:20 PM
Iroc_man's Avatar
Car: 87 Iroc
Axle/Gears: stock posi
sometimes when the fuel system has pressure in it, the fuel pump wont kick on. it does not kick on every time.
Old Sep 3, 2006 | 04:41 PM
91GTAWS6's Avatar
Engine: 305 (310)
Axle/Gears: 3.73's
i'm aware that the pump should not prime each time, but in the morning, when the car hasn't been touched in over 10 hours....it should prime. not only is the pump not priming, but the car won't start. it will crank over, just no start.
