How can I tell
Old Sep 11, 2006 | 06:27 PM
TONY LAVIGNE's Avatar
How can I tell
I own a 1987 Pontiac Trans AM GTA how can I tell if it has a L98 350????
Old Sep 11, 2006 | 07:07 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
If the motor is original, run the vin that should give you an idea of what motor you have.
Old Sep 11, 2006 | 08:01 PM
First/Thrid Gen's Avatar
Car: 68 Camaro
Engine: 5.7 TPI
Look behind the heads on the bell housing part of the engine block, I forget wich side but it will have 5.7 in large letters. Then check the intake manifold the center 2 bolts on either side will be at a diferent angle then the rest. And the tpi intake, and if you have a automatic pretty much would have to be a l98.
