Question on hesitation
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Hey guys,
Car is a 91 Z, 305 TPI, auto tranny. When the car is cold, it gets up to speed ok till it hits about 50mph. Then it acts like it just doesnt want to go anywhere. Its most noticable in OD, but while it isnt as bad in Drive, its still there, and only when cold. Once the car gets up to operating temp, it accelerates fine. I'm getting an intermittent Code 44 which I THINK is for the knock sensor. Any ideas?
Brian
Brian
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
Code 44 is for a lean mixture (IIRC the knock sensor code is 42?). Either the oxygen sensor is going bad or your fuel injectors might be plugged, would be my first guesses.
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Check that you're getting spark to each plug as well. A cylinder not firing becomes more noticeable as you pick up speed.
Car: 91 Camaro Z28
Transmission: 4L60
Ok, thanks for the tips guys. I have some newly cleaned and flow matched injectors at home waiting to be put in anyway ... guess I know what I'm doing this weekend.
