Maybe is the fuel pump !!!
Old Sep 20, 2006 | 10:01 PM
camaro350tpi's Avatar
Car: camaro iroc-z 89
Engine: 383 HSR SC MegaSquirt
Transmission: tko 600
Axle/Gears: 9 Inch 3.75
hi, i have a 89 camaro , my car always start on the morning when it sitting all night... but if i let it run like 10 min max and then shut it off it wont start again , it turn right i have fire on plug and a signial on the injectors and the fuel pump is running .... what can cause that , you have an idea !?!??
Old Sep 20, 2006 | 11:54 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
it could be an overheating module in the dizzy. if it doesnt have enough dialectric grease, it won't stave off heat very well. I've used petroleum jelly successfully in the past.
Old Sep 21, 2006 | 12:06 PM
nah i dont thinks the module overheating , it a new gm module and put the grease comes with the module , i have anyway because i have fire and injector signal...
Old Sep 21, 2006 | 02:56 PM
Car: '85 TA
then I'm stumped
Old Sep 21, 2006 | 06:46 PM
jocool's Avatar
Car: 89 Iroc & 88 Firecird & 86 Camaro
Engine: 350 TPI & 305 TBI & 305 Carb
Have you checked fuel pressure at the schrader valve?
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
