Need some advice.....
Old Sep 22, 2006 | 06:40 AM
pinky93's Avatar
Car: 1989 IROC-Z
Engine: 5.7
Transmission: 700R-4
Axle/Gears: 9-Bolt Borg-Warner 2.77
Ok.... 89 IROC w/ 5.7 -Auto. 58,000 one-owner miles. Completely stock except for a Hypertech chip. I have just purchased the car and it runs beautifully. It sometimes needs some gas when starting, which I found funny. Otherwise, it usually starts and idles fine.
But..... sometimes, it wont idle at all. So far, it seems to happen after you have driven it for a bit and heat soaked it, but not always. If you can run it on the highway for a few miles it will idle fine. However, if you are in stop and go traffic, you have to keep your foot on the gas when you let off or it dies.
Any thoughts?
Thanks!
Old Sep 22, 2006 | 12:25 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Try and go to an auto parts store and have them check the computer for error codes. Last time I heard advance auto parts does it for free.
Old Sep 22, 2006 | 01:06 PM
pinky93's Avatar
Car: 1989 IROC-Z
Engine: 5.7
That is one thing that baffles me. It is not flagging any codes. No Check Engine Soon light or anything.
Old Sep 24, 2006 | 06:30 AM
pinky93's Avatar
Car: 1989 IROC-Z
Engine: 5.7
Bump
Old Sep 24, 2006 | 08:37 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
first thought is the chip is causing it. Do you have the stock chip still, to try?
Other then that, vacuum leak, or TPS /MAF (or whatever controls idle air flow on that car), could be screwy - but that would typically throw a code.
58,000 miles, it should run showroom floor style. Does the previous owner know anything about the weird idle issue? that's usually the easiest way to track down a problem with a new vehicle, ask the PO!
Old Sep 24, 2006 | 09:35 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Check your burn off relay and then check/adjust your tps and iac per the tech article.
Mr.Franco
20
Jan 18, 2013 07:50 PM
ShadowWulf
Mar 13, 2006 04:41 AM
idrag2
Dec 27, 2001 06:43 PM
