guide to retainer clearance.
Old Oct 5, 2006 | 05:56 PM
ReidK's Avatar
Car: 1988 Firebird Formula t-tops
Engine: 350 60 over...400 HP
Transmission: 700 r4 transgo shift kit
Axle/Gears: stock...373?
I'm buying a lunati voodoo cam and I need to know how much lift, before retainer and valve guide contact. My heads are HO 305 heads with 2187 casting number.
Old Oct 5, 2006 | 07:05 PM
Damon's Avatar
The vast majority of factory/stock SBC heads start to get dicey over about .470 lift and retainer to guide (seal) clearance is the reason.
Old Oct 6, 2006 | 05:52 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
187 casting heads? hmm...
You can measure it. I might suggest using .050" offset locks, it's cheaper than machining, and gives you a bit more safety margin. I think that's what i've got on my 305 heads, when I had my lunati voodoo 60103.
Bubbajones_ya
Oct 25, 2015 08:01 PM
sandman92084
Sep 12, 2015 10:27 PM
