Waterpump Question
Old Oct 6, 2006 | 10:11 PM
cohan305ci's Avatar
Car: 87 Z28
Engine: 305 ci TPI
Waterpump Question
ne one know if its complicated to replace a waterpump, for a fuel injevted 305?, if so wat shud i lok out for?
Old Oct 7, 2006 | 12:22 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
It's not hard.
Old Oct 7, 2006 | 08:27 AM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Less that a 1/2 hour job easy
Old Oct 7, 2006 | 09:12 AM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
i just did myn in my driveway, on a 87 you gotta loosen the bracket for the power steering pump, ( the usual slide the alternator down or off.. makes more room and releases the belt) Then its mainly 4 bolts, transfer the pully on to the new one and bolt it back up(dont forget gaskets), tighten the power steering pump bracket, and tighten up the alt/belt...
DO NOT, forget to have a drain bucket because if u live in a place similar to me you may have dead cats under your car in the morning
Old Oct 7, 2006 | 08:40 PM
cohan305ci's Avatar
Car: 87 Z28
Engine: 305 ci TPI
thnx, im just waiting for it to stop rainin so i can get it done, it doesnt sounds that bad
Old Oct 10, 2006 | 07:16 PM
cohan305ci's Avatar
Car: 87 Z28
Engine: 305 ci TPI
heres the update on it, well, i replaced the waterpump, still knockin hard, my dad says the engine is done for, so im savin up for a crate engine for it, till then its gonna sit in my driveway for about the entire winter, lol
Old Oct 10, 2006 | 07:20 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
U were replacing a waterpump to fix a knock? I'm confused..
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
